Toyota Supra The 2020 Supra Performance Story
Minneapolis
The 2020 Supra will feature a 3.0-liter turbocharged inline six that will produce 335 hp and 365 lb-ft of torque. The torque comes on strong from very low engine speeds, thanks to a combination of a twin-scroll turbocharger, direct fuel injection and continuously variable timing on both the intake and exhaust camshafts. Engine response is further enhanced thanks to the inline six’s variable intake valve lift system that adjusts intake valve timing and duration.
The 8-speed automatic transmission delivers quick up- and downshifts and features paddle shifters for manual control when desired. Short ratios for the lower gears and a Launch Control function enable powerful acceleration with maximum traction. Toyota estimates 0-60 mph acceleration in 4.1 seconds. Top track speed will be electronically limited to 155 mph.
The 2020 Supra will offer two driving modes, Normal and Sport. Sport Mode provides track-driving capability by reducing intervention of the traction and stability control functions as well as sharpening throttle response, increasing steering weight, improving transmission shift crispness, more aggressive active differential tuning and amplifying exhaust sound.
For performance driving enthusiasts, the Supra will have an active differential that uses an electric motor and multi-plate clutches to control lateral torque. The active differential precisely controls torque distribution between the rear wheels, with stepless variable locking from 0-100 percent. The differential can control torque distribution between the rear wheels when cornering under both acceleration and braking, enabling greater momentum through a corner. The active differential is also effective at ensuring neutral handling by reducing both understeer and oversteer.
Chassis: Lessons from the Track
Toyota GAZOO Racing had a specific vision when developing Supra. High structural rigidity, a low center of gravity and 50:50 weight distribution were paramount to Toyota’s goal of achieving neutral cornering balance. For example, Toyota identified nine areas of the vehicle’s rear structure to be reinforced to increase rigidity.
Toyota also specified spring and shock absorber tuning for the new double-joint spring strut front suspension and multi-link rear suspension. Likewise, Toyota set specific parameters for the Supra’s stability control system performance.
The front suspension subframe and control arm mounting points are extremely rigid to yield precise cornering characteristics. Aluminum control arms reduce unsprung weight, resulting in superior agility and efficiency. High-performance wheel hubs feature increased stiffness and optimized kinematics. For precise handling, Supra features a variable assist and variable ratio sport-tuned electric power steering.
The multi-link rear suspension with a five-arm construction consists of lightweight aluminum to reduce weight while steel is employed in key areas for added strength and durability. The rigid rear subframe, and the bracing that connects it to the body structure, helps ensure extremely precise wheel control. Supra will come standard with 19-inch forged alloy wheels. The rear wheels and tires are wider than on the front (rear tires: 275/35R19; front tires: 255/35R19) to enhance grip, and performance Michelin Pilot Super Sport tires are fitted. Brakes are large at all four corners, highlighted by 13.7-in. front rotors held by 4-piston Brembo calipers.
Standard on all Supras is Adaptive Variable Suspension. Adaptive Variable Suspension system instantly adjusts damping force in response to driver input and road conditions. Two settings for the suspension are available - Normal and Sport.
Road and track development took place in France, Austria, Italy (including many winding roads through the Alps), Germany (including the Nürburgring track), Sweden (ice and snow road testing), the U.K., Japan, Australia, and the U.S. A global citizen, the new Supra will be assembled at Magna Steyr in Graz, Austria.
GT Comfort, Maximum Multimedia
Like its 1990s predecessor, the 2020 Supra will be equipped as a premium GT, with a deft balance of function and premium comfort and convenience features. Keyless Smart Entry, dual automatic climate control, auto-dimming rearview mirrors, rear camera, rain sensor windshield wipers, garage door opener, power folding mirrors, and a leather-wrapped steering wheel will be standard.
Standard active safety features include forward collision warning, automatic emergency braking with pedestrian detection, lane departure warning with steering assist, automatic high beam and road sign assist. Additional active safety and convenience features available are adaptive full speed cruise control, blind spot monitor, rear cross traffic alert and rear end collision warning.
The new-generation Supra will of course deliver a state-of-the-art multimedia and connectivity experience. The 3.0 grade features a 6.5-inch display that can be operated by the rotary controller on the console, as well as Bluetooth and iPod capability. The 3.0 Premium grade will get an 8.8-inch touchscreen display with navigation, rotary touch controller, Supra Connect telematics services, wireless Apple CarPlay, a premium 12-speaker JBL audio system, and wireless phone charging. The JBL audio system and navigation will be an available option on the 3.0 grade.
50+ Years of Toyota Sports Car Heritage
The 2020 Toyota Supra traces a 50+ year lineage to Toyota’s first sports car, the 1965 Sports 800. This sleek but tiny (140-in. long) coupe offered a little over 40 horsepower from an air-cooled, two-cylinder boxer engine. The Sports 800 weighed just 1,300 pounds and could reach 100 mph in racing trim. It was successful in long distance races where reliability and fuel economy worked to its advantage. Here’s one for car trivia buffs: The 800 Sports was the first production sports car to have a lift-out aluminum roof panel.
2000 GT
In 1967, Toyota stunned the sports car establishment with the limited-production, hand-built 2000 GT. This six-cylinder, two-seat coupe smashed three world records and set 13 new international records for speed and endurance. Just 351 of the 2000 GTs were made, about 60 of those left-hand-drive for export to the U.S.
Nevertheless, many Americans saw the 2000 GT when a specially built roadster version was the automotive star in that year’s James Bond film, You Only Live Twice. Today, 2000 GTs can approach $1 million in collector-car auctions.
Age of the Supra
In 1978, Toyota introduced the first Supra (A40) as a premium, six-cylinder version of the popular Celica sports coupe. Four years later, Toyota began to separate the Supra from the Celica, with the second generation (A60) featuring a completely different front-end design and a striking Performance model with wider wheels and fender flares.
With the debut of the third-generation model for 1986 (A70), the Supra became its own distinct car. The following year, the Mk. III, as Supra aficionados call it, debuted a Turbo upgrade model with 230 horsepower.
Then came the icon: the fourth-generation Supra (A80, or “Mk. IV” to Supra buffs) arrived in 1993 and upended the global sports car / GT hierarchy. The Supra Turbo used twin sequential turbochargers to extract 320 horsepower from its 3.0-liter inline six. This utterly unique sports GT could accelerate from zero-to-60 mph in under 5 seconds, trouncing direct competitors, as well as some European models costing 2-3 times as much.
The Mk. IV Supra left Toyota’s U.S. lineup after 1998 but was produced until 2002. It went on to become famous for new generations in video games and in the Fast and Furious film series, stoking an intensely loyal following that helped spur Toyota to develop the all-new, fifth-generation Supra for 2020.
Toyota GAZOO Racing
The 2020 GR Supra is the first global model developed by Toyota GAZOO Racing, the international umbrella for Toyota's global motorsport program. In just the past year GR won the Le Mans 24 Hours race and the FIA World Rally Champions. Its work is based on three pillars: developing people through taking part in motorsport; creating fans through the excitement of motorsport and producing fun-to-drive cars; and making ever-better cars by applying the knowledge gained from motorsport competition.
This ethos has been fully embraced by both Kiichiro Toyoda, founder of Toyota, and Akio Toyoda, Toyota Motor Corporation president, for its goal of “making ever-better cars.” Starting with this Supra, Toyota GAZOO Racing will transfer technical learnings from the race track or rally stage to the development of not just new generations of Toyota's sports-focused GR models, but also to its wider range of vehicles, driven by tens of millions of people around the world.
With the 2020 Supra, Toyota is seeking to ignite automotive enthusiasts with fond memories of the Supra, as well as spark a new wave of sports car fans around the world.
